Don't know what happened. They are all gone in my parts and assemblies. Only are they visible in the browser when I open a particular part or assembly of the parent. Need them for constraints ... HELP... IV2014.
Solved by karthur1. Go to Solution.
Check under your View Tab, work-plane visibilities. You may have turned them off for the specific parts and assemblies.
No that's not it ... all work features are checked visible for all parts and assemblies.
Thanks though ,,, any other thoughts?
Possibly you don't have the latest updates for Inventor to add full compliance for your operating system.
It tells me my product is up to date. I am using windows8.1. Is there an issue with win8.1?
I discovered that this is a problem with the current assembly I'm working in...a new assembly shows the origin and etc in the assy and part file.
You need SP1 and the Update for SP1 for Inventor 2014 with Win 8.1
Don't rely on the ont Product Update within Inventor. The bottom of this page has links for the service and packs & updates.
Well I downloaded and installed SP1 and it's update (thank you) but alas there is still some elusive setting or parameter in this particular assy file that does not show the origin folder in the browser. I also opened up some other assy files and they also along with new files show the origin folder in the browser.
How do I fix this particular project? ... makes contraining parts a huge pain.
Rob,
You (or someone) has turned off the Work Features visibility. Its the filter button on the far left.
Kirk
You just beat me to it, need to cut back on the Nog this time of year.
