Excuse me, I realize that what I said is false. If one of the objects has a
dimension on it, you can't add an equal constraint.
"mpower" wrote in message
news:33F8E980804913A18E7A091C3ADD0DC3@in.WebX.maYIadrTaRb...
> I noticed this about a week ago. Please try this senarion and see if it
> works for you.
> Start a brand new part. Project the center point into the sketch. Make a
> rectangle using the 2 point rectangle tool by starting on the projected
> center point. Add a dimension a vertical leg. Now add an equal
constraint
> between the dimensioned vertical leg and a horizontal leg to make the
> rectangle a square.
> When I do it, IV gives me an error about this constraint will over
constrain
> the sketch, which is false. I swear I used to be able to do this! It
seems
> like if one of the objects has changed color indicating that it is fully
> constrained, you can't add an equal constraint.
> If you create the rectangle in free space (no coincident constraint with
the
> projected centerpoint) it works fine.
> Am I losing my mind?
> Mike
