Show only
Search instead for
I want to know if there a way to turn off symboles visibily and work plane visibility permanently in a weld assy. Because wend I put a weld assy in a assembly the weld symbole are always show even if it's turn off in the weld assy.
In assembly file, goto menu "View"->"Object Visibility"->"Weld Symbols" to toggle on & off as required. For some reason, however, it doesn't appear to be related to the application, but rather to the file.
