Attached here is a weldment that doesnt want to cooperate. All is well with the assembly when I open it (no red cross). When I change the length of extrusion 2 in -077-ta from 20.25in to 15in, all the welds in the weldment fails for no obvious reason.
I tried to edit the welds and fix them, but nothing that I try works. Next thing I tried was to delete all the welds and just recreate them. This doesnt work either. I get the error "weld compute faild due to a modeling error".
Am I missing the obvious?
Kirk,
This is quite strange. I cannot seem to reproduce the problem on R2011 or R2012 by using the dataset you attached and the steps you described. Did I miss anything? Could you attach a snapshot of the failed state?
Thanks!
Simply amazing... I scratched my head over this for an hour this morning. Now, I was going to record a video for you to show you my steps and I cant get it tofail to save my life....
Kirk,
I suspect maybe the solver was in a bad state. It might have something to do with prior operations causing the solver to confuse. If you can reproduce it from scratch, please let me know asap.
Thanks!
