When placing a branch (olet), the placement green dot turns yellow when the end of the run is approached, guessing this is a limit to stop braches being placed too close to the end of a pipe.
What drives this value ?
How can it be editted?
I'd like to place olets closer to the end of the pipe.
MES
It might be related to the Minimum Segment length set in your Tube & Pipe style. I've never run into this problem, so I'm not sure. but I have my minimums lengths set to .001". Try playing with that and see if it makes any difference.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
