Inventor General Discussion
Distinguished Contributor ijc
ijc
Message 1 of 13 (528 Views)
Weldment
528 Views, 12 Replies
10-26-2010 04:48 AM
The file attached contains a main pipe with 4 flanges mated onto the pipe.I have not used the Weldment feature before so would please like some guideance and help.What steps would i use to Weld the 2 small upright pipes on top of the main pipe and Weld the 4 flanges onto the 4 small curved pipes underneath the main pipe?
Any help appreciated.....IJC
blair
Message 2 of 13 (506 Views)
Re: Weldment
10-26-2010 04:11 PM in reply to: ijc
First, you need to either convert this existing model to a Weldment, or start a new model as a weldment. Then enter the Weld Module. The rest is straight forward, or read the "Help"
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.75
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
ijc
Message 3 of 13 (500 Views)
Re: Weldment
10-26-2010 04:26 PM in reply to: blair
Blair...thanks for the reply....will take your advice and follow.
Blair is also possible to use Weld where i attached the 4 flanges onto the curved pipes under the main pipe?
Best Regards
IJC
blair
Message 4 of 13 (495 Views)
Re: Weldment
10-26-2010 04:29 PM in reply to: ijc
Yes, it's done the same way.
Win7-64
Delta Tau Chi ΔΤΧ
ijc
Message 5 of 13 (493 Views)
Re: Weldment
10-26-2010 04:30 PM in reply to: ijc
Thank you
ijc
Message 6 of 13 (459 Views)
Re: Weldment
10-27-2010 05:29 AM in reply to: ijc
I was able to weld the 2 end pipes but was not able to weld the middle pipe.I used the same technique as the 2 end pipes but could not get it to work.I also tried some other welds but again would not work...What technique is required to weld the middle pipe onto the bottom pipe?
Thanks....IJC
blair
Message 7 of 13 (436 Views)
Re: Weldment
10-27-2010 08:39 AM in reply to: ijc
Your IAM file is useless without the required IPTfiles
Win7-64
Delta Tau Chi ΔΤΧ
ijc
Message 8 of 13 (418 Views)
Re: Weldment
10-27-2010 04:31 PM in reply to: blair
Here is the file..thanks
blair
Message 9 of 13 (413 Views)
Re: Weldment
10-27-2010 04:51 PM in reply to: ijc
The files you sent only contain a single part "Part1" and it's a flat plate with a slot and a couple of other holes.
Win7-64
Delta Tau Chi ΔΤΧ
ijc
Message 10 of 13 (409 Views)
Re: Weldment
10-27-2010 05:08 PM in reply to: blair
Will this picture help..The large pipe in the middle without the weld is the one i cannot get to work... Both pipes are 3" in diameter...thanks again
