Thanks Gary, well the cosmetic weld type give me the look, which is obtained
after surfacing (grinding or machining) the weld bead?
Bob
"Gary R Smith (Autodesk)" wrote in message
news:91949ADA56986A56C67105EEEB35C729@in.WebX.maYIadrTaRb...
> > Can I use Inventor weldment tools to weld
> > sections of plastic material together, to form a water tank? TIA, Bob
> Hi Bob,
> Yes you can however we only supplied a few pre-defined weldment materials
> (assuming you want to do fillet-type welds). You can define your own
> material for your weld bead - give it the material properties of the
plastic
> you are using.
> Or,
> Use the "cosmetic" weld type.
> G
