Inventor General Discussion
arto.ww
Message 1 of 10 (401 Views)
Weldment problem
401 Views, 9 Replies
03-31-2013 09:09 AM
How can I make a weldment in these kind of situtation? Arrow is pointing where I want weldment to be.
There's cut in circle part and other part is filling that to half way. How can I fill that with weld?
Thanks:smileyhappy:
When you see a "Cross-Part" error, this usually points to "Adaptively". When you clear (un-check) the Adaptively on the parts, the welds in the "slots" can be made.
blair
Message 2 of 10 (393 Views)
Re: Weldment problem
03-31-2013 09:42 AM in reply to: arto.ww
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
JDMather
Message 3 of 10 (380 Views)
03-31-2013 09:55 AM in reply to: arto.ww
This assembly is designed incorrectly.
A 20mm hole will not have any material for threads.
And a 20x8 box will not fit into a 20x8 hole (unless the parts are made to very tight tolerance and press fit).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
arto.ww
Message 4 of 10 (328 Views)
04-01-2013 08:20 AM in reply to: arto.ww
Blair: That did the trick. Thanks!
Now I can make fillet welds around the slot. Is it possible to fill that slot with one weld? If you know what I mean.
JDMather: Yes it might be incorrect, I'm just learning. I thought that when I put thread in same size extruded hole would be correct way. Perhaps it would be easier to use Hole command with thread option.
blair
Message 5 of 10 (316 Views)
04-01-2013 10:04 AM in reply to: arto.ww
Select the"Base surface for your #1, then select the four sides for your #2. You will then get all four sides under one fillet.
Win7-64
arto.ww
Message 6 of 10 (296 Views)
04-01-2013 11:09 AM in reply to: blair
Yes I did that, but I don't mean that now. I mean is there a possiblity to make one single weld, one bigger weld which is edge to edge in that slot.
blair
Message 7 of 10 (271 Views)
04-01-2013 01:31 PM in reply to: arto.ww
Look at "Groove Weld"
Win7-64
arto.ww
Message 8 of 10 (249 Views)
04-01-2013 10:29 PM in reply to: blair
Yes that works. I tried it before but I chose faces from different parts, that didn't fill the slot. Now I chose faces from same part (circle), opposite sides of slot. That filled the slot entirely.
But if I do a stress analysis to this weldment, it would be better to put fillet welds around slot faces?
blair
Message 9 of 10 (245 Views)
04-01-2013 10:46 PM in reply to: arto.ww
Most of my FEA work is done in Mechanical Simulation. I'm not sure how the FEA within IV would treat the zero-gap items and how it reads/treats welds.
Win7-64
arto.ww
Message 10 of 10 (243 Views)
04-01-2013 10:49 PM in reply to: blair
I don't need that FEA, just a question what came in my mind.
Thanks for your answers!
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
