Hello, I have a weldment made from elevent parts originated from a skeletal file. In the weldment I created some machning features from sketches that were projected from the sketches in the skeletal file. Later in the design process the machining shape and size required changes. These changes were done from the skeletal file. Then I thought I could see those changes done in the machined assembly. But they were not. So what did I not do correctly?
Thanks. Kind Regards.
Serge
Solved by blair. Go to Solution.
This is the steps you followed.
1.) Create Skeletal Model
2.) Push Skeletal Model into IAM assembly
3.) Convert IAM model to Weldment
4.) Use Weldment/Machining to create "Prep" features.
5.) Make changes to Skeletal Model
6.) Open IAM Weldment as see changes in all related IPT files
Hello Blair,
Thank you for your reply. In a streak of luck while I was waiting for a reply, I did some searching and I found the answer to my own posting back in 2008 under the subjetc "Skeletal Modeling-Assembly_Machining".
Again, thank you very much.
Kind Regards
Serge J.
Do you seriously really need to see files to believe me? Seems like a delaying tactic at best...
Try it for yourself, and see if it works. I can tell you it doesn't. You guys really need to go out and work in an Engineering office for a couple of months on Inventor and then on another program to see how far Inventor has fallen behind
Hi Sam,
The issue he runs into is a long limitation in Inventor. A part sketch is not associatively projected to an assembly sketch. It is indeed a limitation. Associativity retains if the project source is body geometry, not sketch geometry.
I am trying to understand the workflow and see if there is a better workflow here. I think the workaround is to extrude the skeletal profile as a surface. Then project the surface edge to the assembly sketch. It will be associative.
Many thanks!
Hi Johnson, I am not a programmer so I probably don't fully appreciate the complexity here. Just thinking if it can be done successfully with a body or surface, how hard would it be to make the leap to sketch geometry?
Hi! I am not a developer either. I am not saying it is totally not doable. However, there must be some technical challenge blocking the workflow. It should be doable but it has not been done yet.
Many thanks!
