Certainly it affects productivity. To make the list complete we will also
have to consider the following:
1. Copy
2. Mirror
3. Combine/Uncombine
of components, weld beads and machining features like the holes. Thanks.
Shekar
"JayK" wrote in message
news:40d87990$1_1@newsprd01...
> I would agree that it needs more work.
> Thanks
> "3D User" wrote in message
> news:40d877a4$1_3@newsprd01...
> > How do you achieve a high level of productivity using the IV "weldment"
> > environment if you can't array features? Seems like weldments are not
> ready
> > for prime time.
> > 3D User
> > "Shekar Subrahmanyam[Autodesk]" wrote in
message
> > news:40d858f0$1_3@newsprd01...
> > > Hi Jay,
> > > Yes, this is correct. There is no known way of arraying the hole
in
> > the
> > > weldment.
> > > We are aware of this issue. This not only applies to holes but
> also
> > > the weld beads, etc.
> > > Shekar[Autodesk]
> > > news:40d8411d$1_3@newsprd01...
> > > > I just made a weldment from an assembly and now I need to put a ton
of
> > > holes
> > > > in the assy.
> > > > I tried to array the one hole I made but it doesnt allow me to array
> the
> > > > hole but will array the sub component.
> > > > Is this correct?
> > > > If so, is there a way to array the hole in the weldment?
> > > > I dont want to put holes in the individual components as it wont be
> > built
> > > > that way.
> > > > TIA
> > > > Jay
