You could have saved yourself a LOT of time and trouble
by:
1. Posting the Inventor version used. We cannot read your
mind, not can someone post a solution in your version without that info. ( I do
not have R10 installed on my system any longer.)
2. Posting the actual files.
3. Posting your test files earlier.
In your test files, I see several things not needed, ie; the
splits on both parts. Not needed. Remove them and associated work
features.
1. The pin is exactly the length of the plate's thickness. Why
would you do this in real life? Make the pin longer.
2. Split the pin only, AROUND the circular face, so that it
has a face .02 longer than the plate thickness. Constrain the pin flush to one
side of the face. (Mate/Flush or your original Insert constraint
works.
3. Proper Pick sequence and settings are attached. Filean
result - next reply.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000 AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
