never used a welding assembly before and im having some issues getting the welds to match the drawing, when i attempt them myself 6.35 appears to be way too much compared to the drawing, what am i doing wrong? 😞
Attaching assembly files and drawing.
Thanks in advance.
Yeah, that's what I mean, those weld fillets don't match the drawing. Right? 🙂 A weld fillet of around 2 matches though, is the fillet simply incorrect on the drawing?
They match the Fillet Leg requirements of 6.35mm. This is why they look larger/wider on the face view.
Sorry, I'm not sure what you mean 😞
The drawing has a 3D view and they don't seem to match mine when I add those fillets. Just doesn't look right..
I assume you mean the shape or length of the leg on the one view is larger on the front view from the side view. If you look at the picture I posted you will understand what Inventor is doing. Because the one leg wraps onto the curved body it must lap over the body to get the correct leg length on curved surface.
I kind of understand what you mean. But to get it to match the drawing in size, what do I have to do? I must be doing something wrong, as it looks nothing like the drawing when i add the 6.35 welds. Sorry, as I said it's the first time i'm doing this sort of assembly so I'm kind of flying blind.
