Inventor Forum
weld size fea
1 REPLY 1
CAD-One
301 Views, 1 Reply
weld size fea
I am using inventor professional 2013.
I need help with analizing this aluminum pipe weldment. This part is clamped using 2 1/4-20 bolts thru the holes to a rigid wall. I want to know if the weld size is adequate to hold 200lbs load. How can I go about this ? Please see my questions.
1. We don't use the frame generator. Its just a simple assembly made of extuded parts. Should it be converted to a weldment to get weld fillet size results?
2. Should it be a ipt or iam? which is better?
3. Apart from the weld size, I want see if the pipe wall thickness is adequate enough to hold 200lbs load.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
1 REPLY 1
jingyi.liu
in reply to: CAD-One
Are you aware of Weld Calculator tool in weld environment? It should be helpful to calculate your weld case.
Jingyi Liu
Inventor Product Manager
