Imagine a channel (the part with the tapped holes) which does indeed have
fillets on it's tips, is going to be inserted through a large rectangular
tube. I basically want to make a rectangular cut in the side of the tube
the same dimensions as the channel. Since you can't get sharp corners with
an end mill I put in the relief holes in the corners.
However three of the sides of the channel are touching the sides of the cut
out in the tube. This should allow for a fillet weld.
Now that I think of it I wonder if this is related to my "weird view"
problem (above). It's the same "spine" part...hmmmm
Thanks Tim...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Tim W" wrote in message
news:8B429922FD55865DE7C11569ED8859DE@in.WebX.maYIadrTaRb...
> Not an answer but an observation:
> The solid piece of metal with the three (visible) tapped holes in it looks
> like an optical illusion. It looks like there's a few fillets in it (near
> the top right hole), but the part you're welding to has a rectangular
shaped
> cut-out area (with circular reliefs). I'm just not sure what's going on
> there... but it may be because I can only see a portion of the parts.
> Tim W.
> "Sean Dotson" wrote in message
> news:C2FAFE291272845671457DA0A7DD3835@in.WebX.maYIadrTaRb...
> > See CF (the old one not the new one) same topic...
> > This is the case in both 6 & 7. Why won't it allow a cosmetic or real
> weld
> > here? Seem like this situations fits within the current weld
limitations.
> > Because of the holes in the corners?
> > Sean Dotson, PE
