Having recently created a weld calculation i now wish to save it and print it out.
When i do this a message comes up "Adobe reader could not open WELDFILLETSPA.htm because it is either not a supported file or because the file has been damaged (for example, it was sent as an e-mail attachement and was,nt correctly decoded.
Any suggestions please.
I assume that a weld caculation can be saved as a report in the same way as a stress analysis report.
Regards
Solved by blair. Go to Solution.
Thanks JEANCHILE
Thats the sort of thing i was looking for.I will try to get that method sorted,its just so much better when you have something tangible in front of you,as they say "a picture paints a thousand words"
Regards
