When I try to place dimensions on my assembly, they are not oriented correctly with the view. When I try to place a horizontal or vertical dimension, they are jacked..... see below.
When I edit the view and choose "Change View Orientation", I have noticed that the cooridinate triad is not position correctly.
How do I get the triad to be "Normal" to the part? I assume that this is why my dims are jacked.
I can't change any of the part positions, because other idws have already be made that use this part and that will mess up those idws.
Kirk
Solved by Mark_Wigan. Go to Solution.
@Mark_Wigan wrote:
......if the assembly is skewed you can get the idw view dims to sit correctly by rmb on view, dimension type - projected (instead of true).......
That worked for me.
