when I set bending radius of metal sheet to exactly 1 mm something weird happen.
You can see it in the screenshot. It should be as it is on the top (there I set bending radius to 0,999 mm).
How to fix it without using 0,999 mm radius?
Hi! I have seen this behavior before. It is largely due to the bend relief associated with Face2. You can simply do the following to avoid the problem.
1) Edit Face2.
2) Go to Bend tab -> change Relief Depth to 0mm.
After that, corners will behave better.
Thanks!
