I have a idw of an assembly (1100 components, 7k instances) with 5 shaded views on one sheet and 3 on a second. It takes about 40 min to load with no other IV docs open. it is not possible to work in the idw while the views are shaded, i have to convert them to no-hidden (about 1 hr) before I can move the views, add dims, etc. Switching between sheets takes about 15 min.
Switching from the iam to the idw is quick, switching back requires 20-30 min, more if I change the iam.
idws of smaller assemblies (800 components, 2000 instances) take a proportionatly shorter time to open.
This issue has affected me in both IV 10 and IV 11, all service packs.
My retailer, boss, and end customer can duplicate the issue on my files. 1st line Autodesk support can not.
Task manager shows 25% (one logical processer) during the entire open process. Memory alloacted to IV goes to 1.8 to 1.9 GB.
open times have been checked with files located on the file server and localy. This has not affected open times.
the iams open in 2-4 min.
Computer specs
XP service pack 2
2 2.8 GHz xeons, hyperthreading on
3 GB ram
3 GB switch set
Quadro FX 4500
84.26 drivers
OpenGL
SCSI RAID 1 drives
Steve Walton
Inventor 2023
Vault Professional 2023
