I save the part with "Shaded with edges" style, then open. And it is only "Shaded" as before.
Does anybody know how to save the part with "Shaded with edges" style?
Solved by -niels-. Go to Solution.
Hi Yuri,
if you like that style always you can go in :
Tools > Application Options > Display > Use Application Setting > Setting > Visual Style Shaded with edges > Ok
To note that it now is active you new to close and open Inventor, from then that visual style will be always active.
i Hope that it can helps you
Admaiora
I believe there was a topic on this recently, it comes down to either your document settings or the application options.
If you have your application options set to use the document settings, you can set the style with:
Tools > document settings > display appearance
If you have the application options set to use the application options, it will override any document settings.
You can set that at:
Application options > display tab > appearance settings
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
If you want that visual style only for that document, you can go :
Tools>Document Setting>Standard>Display APparence Setting>Visual Style Shaded with edges> Ok
Admaiora
Oops, sorry Niels, i didn't see your post.
Admaiora
Niels van der Veer
The Netherlands
