Inventor Forum
Visual Style: Dynamic simulation
13 REPLIES 13
Message 1 of 14
robmatthews
899 Views, 13 Replies
I'm a bit fussy about my visual style used. I like "Shaded with edges", and I want the edges black. I have set up the display to this setting in Appllication Options, Display tab (Use application Settings), and Settings button. Excellent, that's nice. (I have also mapped the numpad 6 to that style, along with 5 is Shaded with hidden edges, and 4 is wireframe).
However, In Inventor 2014 Dynamic simulation, the visual style defaults to "Shaded" (no edges). Ok, i can live with that, I guess. I'll just hit NumPad 6 and it looks good again.
Ctrl-Tab to another open file, make a change or two, come back to the DynSim and - hang on, where are my edges?? Ok, i can just hit 6 again, but should I have to? I haven't ever seen this display property changed when changing between files before.
Please can this be fixed in an SP?
This is my signature, not part of my post.
13 REPLIES 13
Message 2 of 14
JDMather
in reply to: robmatthews
@robmatthews wrote:
.... but should I have to?
I don't think you should have to.
I don't understand why anyone would work in DS without edges displayed - should be the default in my opinion.
I don't think they see it as a defect.
Message 3 of 14
pcrawley
That get's my vote for fixing.
I thought it was just me.
Peter
Message 4 of 14
henderh
Thank you for bringing this up again.
  It's been in our database for quite some time as ID 1329716.  I bumped up the priority and added a link to this discussion, in hopes it can gain more attention for resolution.
Best regards, -Hugh
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 5 of 14
Justine.Haupt
in reply to: henderh
I realize this is an old postin but the problem is still present in v2015. I recently upgraded from 2011 so this is bothersome to me.
My visual style preference is exactly the same: sshaded with edges, and the edges are set to black. I feel this should be the default visuals style; it's very clean, easy to see, and visually appealing.
~Justine
Message 6 of 14
JDMather
in reply to: Justine.Haupt
Justine.Haupt wrote:
My visual style preference is exactly the same: sshaded with edges, and the edges are set to black. I feel this should be the default visuals style......
~Justine
Don't hold your breath.
Unless it is Fusion - it doesn't get attention.
Message 7 of 14
robmatthews
If its still standard behaviour in 2015, then maybe you need to bump the priortity again...
Message 8 of 14
henderh
Hi Rob,
Would it be possible to add this issue to Ideastation? This way users can vote up the popularity of the request.
Thank you,
-Hugh
Hugh Henderson
Message 9 of 14
WHolzwarth
Smiley Wink My Kudo is waiting ..
Walter Holzwarth
Message 10 of 14
JDMather
@henderh wrote:
Hi Rob,
Thank you,
-Hugh
When Autodesk needs a popularity contest to fix broken stuff, I have come to the conclusion that Autodesk the company is broken, lost their way.
Message 11 of 14
robmatthews
Added to Ideastation, per request.
http://forums.autodesk.com/t5/inventor-ideastation/visual-style-changing-stress-analysis-amp-dynamic...
Message 12 of 14
WHolzwarth
Smiley Wink I did it ..
Walter Holzwarth
Message 13 of 14
LT.Rusty
+1 from me as well.
Rusty
Message 14 of 14
ravikmb5
+1 From myside
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
i7 860 Dell Studio XPS Win 7 64 bit 12 Gb RAM & HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
