style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<zcroyer> wrote in messageWhen
href="news:6175621@discussion.autodesk.com">news:6175621@discussion.autodesk.com...
i double click the icon to open Inventor 2010 nothing happens, I can see it
under the task manager as Inventor.exe but it never loads. -Windows Vista
Business SP1 -Inventor 2010
From the Acresso readme IOA-000040462: FLEXnet Licensing Service
crash on some 64-bit Windows
machines.
The FLEXnet licensing service no longer fails on systems where
the disk drivers have recently been updated.
So to get this to work on your XP64 bit machine, you'd need to
update your disk drivers from the manufacturer and make sure that your system
isn't write protected for the master boot record: At boot time select the
“setup” option to enter he BIOS and look for a setting (usually under security)
that blocks modification of the
MBR.
The same process needs to be followed in the AV software. If you
have an IT department, they can check it out for you.
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
