Inventor General Discussion
Valued Contributor
linuskotte
Message 1 of 5 (326 Views)
Visibility problem
326 Views, 4 Replies
04-09-2013 07:14 PM
Hi
I have a big assembly its consists around 1000 parts and sub assemblies and around 30 representatins in master it's showing all the parts. but in other representetions parts and sunb assemblies are not visible but in moassembly tree parts and sub assemblies showing visibility on.
actually when iam recieved this assembly it's working fine but after done some operations it's not working fine like only in master it's showing all the parts in other representations not showing.
example activate one representation then place one part or sub assemblies also it's not visible.
Please solve my issue.
thanks in advance.
Thanks and Regards,
LINUS KOTTE
*Pro
sbixler
Message 2 of 5 (292 Views)
Re: Visibility problem
04-10-2013 04:59 AM in reply to: linuskotte
If a View Representation is locked, new components added to the assembly will not be visible in that VR.  See if your VRs are locked.  If so, right click and select unlock.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Valued Contributor
linuskotte
Message 3 of 5 (263 Views)
04-14-2013 07:48 PM in reply to: sbixler
this solution is ok for placing components but why its happened in some other VR's not showng any parts.
*Pro
sbixler
Message 4 of 5 (246 Views)
04-15-2013 03:42 AM in reply to: linuskotte
So, you are seeing a mismatch between what is shown in the browser as visible, and what you see on the screen, for at least some of your View Representations?  That sounds like a bug or corruption to me, but I have no means to diagnose it.  Autodesk?
Sam B
Valued Contributor
linuskotte
Message 5 of 5 (219 Views)
04-15-2013 07:15 PM in reply to: sbixler
Here I attached one pdf please see this.
Linus kotte
