Inventor Forum
Visibility Issue in Drawing Environment
25 REPLIES 25
Message 1 of 26
mrattray
538 Views, 25 Replies
I seem to have a few components in this here drawing that refuse to show themselves.
These are two occurrences of a patterned sub-assembly. The one that's missing it's foot and gussets is the first occurrence. This view is set to use the models view rep and is set to associative. It shows up correctly in the model. I've tried playing with every setting I can think of (yes, including graphics compatibility mode and software graphics mode). I've tried restarting the computer, manually updating the view, setting the view's view rep to master, turning off associative, etc. I'm out of ideas. Can anyone else suggest something else to look at that I may have overlooked?
It may be worth mentioning that this is a large assembly (by my standards) and Inventor is dragging **** trying to work with it. Occurrences/Unique Files: 7967 / 119
Here's some system specs in case anyone wants to ask:
Inventor 2013 SP2
Windows 7 SP 1
Dell Precision T5600
Intel Xeon 3.3GHz x 4 Cores
32 GB RAM
AMD FirePro V5900 (2GB)
237 GB SSD
Mike (not Matt) Rattray
25 REPLIES 25
Message 2 of 26
tsreagan
in reply to: mrattray
Under the display options for the drawing view,  did you play with the section all parts, and Cut Inheritance options?
Expand the tree and check the status of the pattern object or missing part from there.
T.S.
Message 3 of 26
mrattray
in reply to: tsreagan
Thanks for the reply. This is my view settings:
I should also mention that these three parts are missing from all four views of the main assembly, but show up fine in the layout for the sub-assembly.
This is the options I have available for the components in question:
Message 4 of 26
tsreagan
In the last screen shot, the entry you have expanded is the first instance of the pattern, which is the one you say is visible.
expand the other elements in the pattern.  the missing part should be grey if it is somehow off.
Try the section participation as well, if they are not greyed out when you reveal them.
if no luck try to change the section standard parts to ALL.
T.S.
Message 5 of 26
mrattray
The first element is the one missing parts, the other 4 elements are correct.
Changing Section Participation does nothing. (As I would expect, since there are no sections on the sheet.)
Message 6 of 26
tsreagan
Hmmm.  Though it was a section.
This makes it harder.  Let me think on it a moment.
T.S.
Message 7 of 26
tsreagan
Notice you are using custom level of detail,  something there maybe.
it is strange that you would have the parts visible in the assembly view but not in the associated drawing view.
try unassociating it and manually making the pattern, the elements, and the individual part under the element, visible on the right click menu.
T.S.
Message 8 of 26
Ray_Feiler
Have you tried increasing the margin under model state?
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 9 of 26
mrattray
Changing to Master LOD is no help.
Indeed.
Visibility is checked when I do this.
Message 10 of 26
mrattray
in reply to: Ray_Feiler
Yes, I bumped it from 5 to 20 and it's no help. The parts aren't marked as reference, either.
Message 11 of 26
tsreagan
I know some things loose visibility if they fall out of the margin,  usually happens on refrenced parts,  didn't know it could happen with a pattern.
Worth checkin.
Save the assembly as a copy,  and remove all but the pattern.
post the assembly, part, and drawing,  we can figure it from there.
T.S.
Message 12 of 26
Ray_Feiler
Try turning on interference edges.
Message 13 of 26
mrattray
No help.
Message 14 of 26
Ray_Feiler
Bummer Smiley Sad
Message 15 of 26
tsreagan
Hmmm...   The pattern has a visibility seperate from each element,  and parts have their own.
did yo check all three?  well two anyway.  as we know the root pattern object is visible.
If the assembly is too big to make a copy or if you think the size of the project may be the culprit,   demote the pattern temporarally and try it by itself in its own assembly.
T.S.
Message 16 of 26
mrattray
I was really hoping for one of those "Just wait until the wind is blowing out of the East then stand on your head for 30 seconds singing Kumbaya..."
Message 17 of 26
Ray_Feiler
Wait, one last thing to try. Make that view shaded just to see if the part will show.
Message 18 of 26
mrattray
When you're in the drawing environment only components have visibility settings. Patterns and pattern elements do not. (Yes, I checked anyways)
Message 19 of 26
mrattray
They don't show up in shaded either.
Message 20 of 26
mrattray
The pattern is of one lone sub-assembly. I have the sub-assembly detailed on another sheet and it shows up fine there.
