Inventor General Discussion
Distinguished Contributor
3 Kudos
Post 11 of 17
Re: visibility in 2d drawings
10-14-2011 04:57 AM in reply to: raymondxu
I have an IDW of a weldment that has the "visibility" of objects greyed out.  This is a two piece assembly that is bolted together and I am trying make the bolts invisible in the section view so that the drilled and tapped holes can be seen.  None of the parts in the browser have "visibility" available when I right click on them.  I've done other weldments just like this one (as far as I can tell) and I am able to turn toggle the visibility of the different parts in the views.
Is there a setting in the IAM or IDW file that makes "visibility" available?
Stuart Kinzel
Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
8GB memory
Windows 7 64bit
3 Kudos
Post 12 of 17
10-14-2011 05:09 AM in reply to: SKinzel
Okay, I think I found the setting.  I edited the section view and on the Component tab under Representation I changed the View from "Default" to "Master".  This cleared the "Associative" checkbox which lets me then change the visibility of ojects in the view.  I've never played with this setting before so I'm not sure why some of my weldments would be set one way and others set another.
Stuart Kinzel
8GB memory
Windows 7 64bit
Product Support
47 Kudos
Post 13 of 17
10-26-2011 05:20 PM in reply to: SKinzel
The problem and solution are also explained on our support blog.
Cheers
Bob
3 Kudos
Post 14 of 17
10-27-2011 05:47 AM in reply to: bobvdd
If I understand correctly controlling the visibility from the assembly would toggle visibility for all views of that assembly.  My issue was needing to turn off visibility of components in only one view.  I guess I'll need to make sure I manually update if I make any changes.
Stuart Kinzel
8GB memory
Windows 7 64bit
Product Support
47 Kudos
Post 15 of 17
10-27-2011 09:07 AM in reply to: SKinzel
You can use a different viewrep per view in the drawing. You  could create yourself a viewerp in the assembly that removes the visibility of a particular part and then use that viewrep just in one view but not in the other views.
Bob
3 Kudos
Post 16 of 17
10-27-2011 11:27 AM in reply to: raymondxu
The problem is that visibility was not available in that view in this particular drawing.  The only way I could get visibility to be available was to change the associativity of the view.
Stuart Kinzel
8GB memory
Windows 7 64bit
*Pro
284 Kudos
Post 17 of 17
10-28-2011 05:32 AM in reply to: SKinzel
You create view representations as needed in the assembly file (.iam).  Each view in your drawing (.idw), if associative is checked, is controlled by one of those view representations, which you choose in the Edit View dialog box.
