When I open a drawing, Inventor 2012 update views. The default option is Background update". The problem is the update never ends... I can use Inventor, but the background update is ne finished, so I can't print a correct drawing.
If I disable Backupdate it is ok, but how can I use it ?
I had the same issue and was able to resolve it by doing the following:
1) In Application Options>Drawing tab I uncheck background updates.
2) In drawing document I opened it with defer updates.
3) Navigated to page with the issue.
4) IN Doc Settings I uncheck defer updates AND changed memory saving mode pull down to NEVER.
After the drawing finished updating the issue was gone.
Hope it works for you too.
