Anyone know if there is a viewer for Inventor?
Solved by DarrenP. Go to Solution.
yea
its called inventor viewer: http://usa.autodesk.com/adsk/servlet/pc/index?id=10535296&siteID=123112
DarrenP
There is also Autodesk true view.
If you have vault there is a viewer inside of that as well.
yes the viewers are free
DarrenP
@Anonymous wrote:I thought the true view could only view .dwg files?
dwg, dxf and some image formats. Not for viewing default Inventor file types.
It does, but you didn't specify what exactly you were trying to view.
I was just giving you more options.
The page was deleted. Is there any other Inventor viewer? My vendor does not have Inventor software but he needs to view my design drawn by Inventor
DarrenP
I found it from google. The link should be
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=18585712
