Hi All,
When i click on the home button of viewcube it rotates such that front, bottom and right sets.
i am not able to get through this problem and its confusing.
Please help...
I am not sure I understand the problem?
Set as you want it and then right click on the cube face or corner to define your desired view or Home position.
Now when you click on Home - the view should be go to however you defined it as your Home position rather than the default.
JD is right. Looks as yo need to "reset home" on the view cube.
