Inventor Forum
View representations of a subassy in a pattern
3 REPLIES 3
A_Harro
211 Views, 3 Replies
Hope someone can help me out here.
In my assembly and i have a pattern of subassy's in it. i want to make the view rep on the subassy the same in every instance of the subassy. At the moment i can only do this by expanding out the pattern of 50 items, right clicking on the subassys and changing the view rep for it.. Surely there is a far more efficient way to do this?  Sadly ive been using inventor for years so its quite embarrasing to ask what should be a very simple thing to do.
Oh, im using inventor 2014 sp2.
thanks if anyone can give me the solution to this.
Regards
Anne.
3 REPLIES 3
CCarreiras
in reply to: A_Harro
HI!
Sadly, i think there's no other way regarding linking all levels of representation in a row...
I think is lacking a tool like the one that link all levels of detail between the main assembly and all sub-assemblys.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
andrewiv
One thing you can do is a search for these files.  If you use the binoculars to find assembly components, once you have clicked on the find now buton it will select all the files that it finds and you can change the representions of all of them at the same time.
Andrew In’t Veld
Designer
A_Harro
in reply to: andrewiv
thanks for the replies.
I have been doing using the search function and changing the view rep that way.. Just thought there should be an easier way.. as we alway hope when we use Inventor 🙂
Guess i'll just have to put up with this and maybe in a future release it could be implemented. 🙂
cheers!
Anne 🙂
