In a multi part ipt file, can we hide different solids and save under different view representation.
Example: the ipt file has 10 solids. I want to split in to 2 groups and save it as 2 different views.
Advantages:
1. I want quickly hide unnecessary parts and work on the required ones.
2. In drawing view, i can show multlple views of top half and bottom half views seperately.
In assembly files, i can turn off the visibility of unnecessary parts. But, here I am working on a multiple solid part file.
Any feed back would be appreciated.
Thanks.
Solved by LaijiLi. Go to Solution.
HI,
Thanks for you reply.
You mean to say, the software has a bug or is the feature is missing?
The feature was designed but not implemented due to time frame. Other higher priority features were implemented instead.
Thank you,
--Laiji
Hi Paul,
I do use Product design suite 2012. Probably I am missing the tric.
Please refer to the attachment.
This part has 2 solid parts. I want to swith on off these parts.
Can you help me please.
