Show only
Search instead for
However I want to modify the size of view label text in the parent view. For example, I want to creat a section view A-A. I want to modify the size of A, A in the parent view not A-A section label in section view.
In Style Editor browser, look for Object Defaults Styles & find the one that
applies to your current Standard.
Click on it & look for Detail View Callout Style in Right hand window.
Under Object Style Heading change the existing imension text called out to
one with a larger Text. If none exist, you need to create one under Text
Styles. "Default-ANSIBIGText" is an exiting one found in thte ANSI Standard
that I happen to use.
Correction...
In Styles Editor under "Object Defaults/Detail View Callout" is referenced a
Dimension Style (not Text Style) so you have to put in a new Dimension Style
that, itself references a larger text style. Mine references "Miscellaneous
Objects" Dimension Style which I edited to have a text style with larger
text.
