Hi guys,
Question regarding view labels in drawings.
I want to change the appearance of the view label to look like attached snap shot. Is this possible? I have looked through the inventor settings but cant find any options.
As a possbile solution I can always create intellegant symbols which update with the drawing (like the standard view labels) but before I begin creating these I wanted to check if there was any other way??
Cheers,
Sandy
No, I don't think there is a way to do that other than symbols. There is an idea submission requesting something very similar though.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Customised-View-Labels/idi-p/4301201
You might check that out and vote / comment on it if it seems similar enough to what you're looking for.
Ok, Cheers jtylerbc,
I was expecting to see that as a reply!
Next question....Do you know of any good threads where I can get code for symbols etc.? Iv used ilogic in conjunction with pararmeters etc before but i dont have the experience to be able to write anything!
Any help would be greatly appreciated. I guess what i need to achieve is
-Code to insert a specific symbol when a base/projected/auxiliary view is created.
-Code to link the Name & Scale of the View to the Symbol Text
Cheers,
Sandy
This forum is one of the better places I've seen for getting iLogic code. However, I've never really done any iLogic coding that involved symbols either, so I can't point you to any specific threads. The only programming I've done that related to symbols in any way is a VBA macro that deletes a particular symbol.
I'd recommend just doing some searches, both here and on the Inventor Customization section of the forum. Most VBA help is in the Customization forum - iLogic gets topics posted in both locations, so you have to check both of them.
SyntaxEditor Code Snippet
This should get you started. It will insert a different sketch symbol based on the type of view it is. (I have section, detail, base and projected view set up already. Might not be a great way to get it done and this is not done yet (I want to attach each tag to its respective view.). I have been able to piece alot of code together from people on these forums so i thought i would give a little back. This code is taken from multiple posts from other users.
Dim oDoc As DrawingDocument: oDoc = ThisDoc.Document oModelDoc = ThisDoc.ModelDocument Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView Dim oSymbol As SketchedSymbol Dim oSymbols As SketchedSymbols ViewLetter = New String(){"A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","X","W","Y","Z"}Dim ViewCount = 0 oSheets = oDoc.Sheets Dim view_asso_draft = 10506 Dim view_auxillary = 10499 Dim view_custom = 10498 Dim view_default = 10497 Dim view_detail = 10502 Dim view_draft = 10505 Dim view_OLE = 10500 Dim view_overlay = 10507 Dim view_projected = 10504 Dim view_section = 10503 Dim view_standard = 10501 For Each oSheet In oSheets oViews = oSheet.DrawingViews For Each oSymbol In oSheet.SketchedSymbols If oSymbol.Definition.Name = "TTLs" Then oSymbol.Delete Else If oSymbol.Definition.Name = "TTL" Then oSymbol.Delete Else If oSymbol.Definition.Name = "DET TTL" Then oSymbol.Delete Else If oSymbol.Definition.Name = "SEC TTL" Then oSymbol.Delete End If Next For Each oView In oViews 'Set label as visible oView.ShowLabel = False 'check view types If oView.ViewType = view_detail Then oView.Name = ViewLetter(ViewCount) ViewCount = ViewCount + 1 'This places a sketched symbol Dim oSymDef As SketchedSymbolDefinition 'define the sketch symbol to be inserted oSymDef = oDoc.SketchedSymbolDefinitions.Item("DET TTL") 'set a string array with values for the prompted entries found in the symbol Dim sPromptStrings(1) As String sPromptStrings(0) = oView.Name'set to view scale sPromptStrings(1) = oView.ScaleString 'set to view name 'set the position for the sketched symbol to be inserted 'and spaced off of the selected view center Dim oPosition As Point2d: oPosition = oView.Center oPosition.y = oPosition.y - (oView.Height / 1.75 + 0.6) 'insert the sketched symbol and set the prompted entries oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings) '------------------------------------------------------------------------------------------------------ Else If oView.ViewType = view_section Then oView.Name = ViewLetter(ViewCount) ViewCount = ViewCount + 1 'This places a sketched symbol Dim oSymDef As SketchedSymbolDefinition 'define the sketch symbol to be inserted oSymDef = oDoc.SketchedSymbolDefinitions.Item("SEC TTL") 'set a string array with values for the prompted entries found in the symbol Dim sPromptStrings(1) As String sPromptStrings(0) = oView.Name 'set to view name 'set to view scale sPromptStrings(1) = oView.ScaleString 'set to view scale 'set the position for the sketched symbol to be inserted ' and spaced off of the selected view center Dim oPosition As Point2d: oPosition = oView.Center oPosition.y = oPosition.y - (oView.Height / 1.75 + 0.6) 'insert the sketched symbol and set the prompted entries oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings) '------------------------------------------------------------------------------------------------------ Else If oView.ViewType = view_standard Then 'This places a sketched symbol Dim oSymDef As SketchedSymbolDefinition 'define the sketch symbol to be inserted oSymDef = oDoc.SketchedSymbolDefinitions.Item("TTL") 'set a string array with values for the prompted entries found in the symbol Dim sPromptStrings(1) As String sPromptStrings(0) = oView.Name 'set to view name 'set to view scale sPromptStrings(1) = oView.ScaleString 'set to view scale 'set the position for the sketched symbol to be inserted ' and spaced off of the selected view center Dim oPosition As Point2d: oPosition = oView.Center oPosition.y = oPosition.y - (oView.Height / 1.5 + 0.6) 'insert the sketched symbol and set the prompted entries oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings) '------------------------------------------------------------------------------------------------------ Else If oView.ViewType = view_projected Then 'This places a sketched symbol Dim oSymDef As SketchedSymbolDefinition 'define the sketch symbol to be inserted oSymDef = oDoc.SketchedSymbolDefinitions.Item("TTLs") 'set a string array with values for the prompted entries found in the symbol Dim sPromptStrings(1) As String sPromptStrings(0) = oView.Name 'set to view name 'set to view scale sPromptStrings(1) = oView.ScaleString 'set to view scale 'set the position for the sketched symbol to be inserted ' and spaced off of the selected view center Dim oPosition As Point2d: oPosition = oView.Center oPosition.y = oPosition.y - (oView.Height / 1.5 + 0.6) 'insert the sketched symbol and set the prompted entries oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings) End If Next Next
