Gentlemen, is there a way to tell Inventor to align the view to be perpendicular to the Origin axes when
View Face or Sketch on face is selected?
It is most disturbing to have to **** with the view cube once in the Sketch just to have it make sense?
This is in Inventor Pro 2012.
Thank You
Wouldn't the "Look at sketch plane on sketch creation" work for you? In the Application Options>Sketch>Look at sketch plane on sketch creation.
It should really work on were ever the sketch is created. The other option might be in the Part tab of the Application options for Sketch on new part creation to have the "Sketch on x-y plane" selected.
Blair
I do have the "Look at Sketch Plane ..." turned on, but after some research I've found that the issue only happens
when the original body is created as a "Revolved" feature.
See attached file.
If I re-create the same part with an "Extrusion" as the base solid, the alignments are always horizontal/vertical
Origin axes.
If you click on any of the face segments on the attached model, you'll see that it orients to some semi-arbitary
angle on the "right" plane.
Hi Acad-caveman,
How strange, I re-created the revolve using 2013 and have the same issue.
If you edit the 30° angle in sketch 2 to say 15° it also re-aligns sketch 5 to the first straight edge of the extrusion.
I agree this would become a pain to work with on a regular basis.
Hope this helps
Cheers
Mark
Inventor 2013
