Inventor Forum
View details in IDW
8 REPLIES 8
Message 1 of 9
Logos_Atum
434 Views, 8 Replies
View details in IDW
Hello there,
given I do a foreshortened view. Is there a way to fit the shortenings parameters to a view in a different window with a different reference file?
If not it would be a little awkward to achieve exactly the same result with a different file. As replacing references does´nt work with single view
representation I´m stuck with manual- non constrained alignment of view details... which can´t be right I guess.
Would be really helpful if there was a way to do it "right" without the need to switch to AutoCAD.
Kind regards
Daniel
Dogs aren´t flammable.
8 REPLIES 8
Message 3 of 9
mcgyvr
in reply to: cbenner
@cbenner wrote:
I suggest you post a picture of what you're trying to do... might jog some ideas.
yes I'm a little unclear of what the OP is asking about too
Message 4 of 9
Cadmanto
in reply to: Logos_Atum
Daniel,
Sounds like you are talking about a broken view and you want to change the model reference to that without changing the mother view?
If that is the case I do not know of a way to do that.
If not, I agree with the others in that posting images would help.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 5 of 9
Logos_Atum
in reply to: Cadmanto
Hello there,
yes a broken view... I want to dimension the "break lines".
I will upload a picture on monday!
Thanks !! And sorry for replying late...
Message 6 of 9
I don't think there is any way to dimension the Break lines. Even creating a sketch and trying to project them fails.
Why do you want to do this?
Message 7 of 9
Logos_Atum
Hello there,
finally a picture to make my explanation work...
It´s a pity, there is no option to dimension the foreshortened view. I tried
to clone the "shortened" view to later change the file path of the reference,
in the copy, but Inventor block´s that option.
Therefore I did not manage. I think I could put all the cranes in one assembly
and use different views for an overlay, but I really don´t think it´s fun to handle
about 250 MB for each crane in one huge IAM file.
Such a pity...
Message 8 of 9
blair
Create your base, view, then shorten it. Then create your secondary views from this base view. They will be the same height and the shorten will be in the same place. You can always drag the view to another sheet in the browser window.
Delta Tau Chi ΔΤΧ
Message 9 of 9
Cadmanto
What Blar is said should work for you.  I have done it so I know it does work.  If this is not what you are talking about please let us know it there was a misunderstanding.
Best Regards,
Scott McFadden
