I have been seeing this for awhile... its hit or miss. I have been ignoring it, but for some reason its really getting on my last nerve. When I rotate my part/assembly to my "front" view, then right click on the view cube and select "Set current view as >Front". Now if I rotate to some other view orientation, and then click on the "Front" view on the cube, I expect it to return back to what I just saved.
For whatever reason, that does not work. The view rep is set to "Default"
How do I get it to save the view?
Kirk
Check your View-Cude Options, possibly your "Fit-to-view" is deselected.
Dear Karthur1
You could also try to "restore defaults" settings of view cube options.
>> right click on view cube >> options >> restore defaults >> ok >> save
I hope that will help
Best regards
