Inventor Forum
view arrow instead of section lines
4 REPLIES 4
slphantom
2102 Views, 4 Replies
is there a way to do this? inventor 2012. for instance for a aux. view if it is not in-line with the parent view it puts a section line. is there a way to have a single view arrow?
thanks
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
4 REPLIES 4
PaulMunford
in reply to: slphantom
I don't think that you can only show one arrow  - but you can right click on the line and pick 'show full line' (or something like that) to turn the line itself off.
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
t_pcoll
Hi Scott,
can you please try RMB on the Aux view definition (the 'Section line') -> Edit View Annotation Style and change the Format to single arrow?
Ladislav
slphantom
in reply to: t_pcoll
Thanks Ladislav. now on that view is there any way to have an aux. views label say View A instead of view a-a?
Scott
win 11 64 bit
Inventor Pro 2023
Space Explorer
t_pcoll
Hi Scott,
you can Edit view label and modify it in the Format Text dialog. You'll find there "VIEW <VIEW>-<VIEW>" - simply edit it to "VIEW <VIEW>" only. If you need to re-add the <VIEW> token again: Set Type of Properties to "View Label Properties", from Properties combo-box select VIEW and insert <VIEW> token to the text. That's for editing existing views.
For the future views you want to edit Standard defaults: Manage tab->Styles Editor->Select your standard->View Preferences tab->View Label Defaults group->Select View Type (Auxiliary) and modify default View label format accordingly.
Ladislav
