Inventor Forum
video card positive
12 REPLIES 12
Message 1 of 13
787 Views, 12 Replies
video card positive
just wanted to say that my quadro 750 xgl is working great on r6... using
driver 30.82... i'm verrrry happy, because i was dissapointed in its
performance when i purchased it for 5.3. Couldn't tell a noticeable diff.
before from my old GVX1.
Brian Land
Mechanical Design
Lorik Tool Inc.
12 REPLIES 12
Message 2 of 13
I'm assuming that driver would also work with the 700XGL? Maybe I'll need
to check that out..
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Brian Land" wrote in message
news:E16B8E1EBB48D29E47AC9410931715F2@in.WebX.maYIadrTaRb...
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
Message 3 of 13
Anyone using a 900XGL?
"Sean Dotson" wrote in message
news:CF7D967AC0195AA46086A256E7DD6538@in.WebX.maYIadrTaRb...
> to check that out..
> Sean Dotson, PE
using
diff.
> > Brian Land
> > Mechanical Design
> > Lorik Tool Inc.
Message 4 of 13
What OS?
-ARF
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
Message 5 of 13
I upgraded to this driver but still see some slight lagging in the sketch
environment. I think I may just wait to see if SP1 clears it up.
Sean Dotson, PE
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
Message 6 of 13
win 2000, custom opengl settings set to (don't ask why...long story)
softimage, full optimization selected in inventor...... Sean said he saw
slight lagging in sketch mode, i do see a little of that also, but overall
performance is good.
"Aaron R. Friedman" wrote in message
news:3DC2A4FE.7000201@xprt.net...
> What OS?
> -ARF
using
diff.
> > Brian Land
> > Mechanical Design
> > Lorik Tool Inc.
Message 7 of 13
I ' sure there are a few that are having no hassles with graphics, but only
a few. This means there is something on the pcs of the masses, that
conflicts with Inv 6 graphics. Another app . direct 3d or something. Never
the less Autodesk need to find out what that is, and I bet its common to OS
as we all have one of those. We see when SP1 arrives
Colin
news:E8CCB691F1F810E8ECBBDCA4055EE725@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
using
diff.
> > Brian Land
> > Mechanical Design
> > Lorik Tool Inc.
Message 8 of 13
loop29
Hey guys,
this is all confusing with certified drivers and stuff. For best use of NV25GL (Quadro 4) core you should install drivers of version 40.71. I noticed a slightly performance increase from 30.82 to 40.71. If it is viewport performance that is bugging you, you can always try to overclock you´re Quadro by a LITTLE. Rivatuner can overclock on low hardware level, no reboot or whatever is required. That´s what I´ve done back in my Quadro 2 MXR days and it helped a lot in viewport performance.
In OpenGL properties make sure that you dissabled vsync. Overclocking can be made by doing 10 Hz increments by core and memory values. When you reached point of instability drope down the frequencies by 15 or 20 Hz.
regards
Message 9 of 13
I am currently using version 40.72  as I was
told it is the only driver version nVidia will fix if problems are
found.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hey
guys,
regards
Message 10 of 13
Yes, without a glitch. I'm using the 30.82 driver og W2K + sp3 and EI 6 +
sp1
Dual Xeon 2.4 with 2 Gb mem. swapfile is static on physical disk no. 2.
I have never had any games /direct 3D applications on my machines. I wonder
it that could be the difference?
Regards
Finnur P.
"Eric Zirkle" <@> wrote in message
news:DCA38945B4AF2B9A22F30C305D532D0D@in.WebX.maYIadrTaRb...
need
> > to check that out..
> > Sean Dotson, PE
> using
> diff.
> > > Brian Land
> > > Mechanical Design
> > > Lorik Tool Inc.
Message 11 of 13
Running 29.42 on a PNY 750 xgl
and 12.41 on a ELSA Synergy III
both under WIN2kSP2
with no problems.
Michael Puschner
michael.puschner@scholle.de
www.scholle.de
"Brian Land" schrieb im Newsbeitrag
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
Message 12 of 13
Running 2.4 Pentium Xenon
ATI Fire GL 8800
win 2k
with very minimal problems
X my fingers and knock on wood ATI
Jesse
Message 13 of 13
You will find the 30.82 driver better, I have not used the 41.03 yet for
synIII.
Laurence,
"Michael Puschner" wrote in message
news:B7C4942A739521EA22E82CD9AB9B1924@in.WebX.maYIadrTaRb...
> both under WIN2kSP2
> with no problems.
> Michael Puschner
> www.scholle.de
using
diff.
> > Brian Land
> > Mechanical Design
> > Lorik Tool Inc.
