I've gone through several online courses and have learned the basics of Inventor. I have a good working knowledge of sketches, parts building, assemblies, and so forth. I came in with a previous knowledge of 3D animating so I can get around in that environment easily enough.
My next logical step is dynamic simulation, and I find myself a bit lost. The tutorials that I've found on the web seem to be a bit over my head and usually seem to take on fairly comlex projects.
Is there a simplified tutorial available out there that can help a "wet behind the ears" guy to understand and start working with DS? I simply desire to learn the basics so I can test a few amusement ride mechanisms that I've dreamed up. I don't really need stress analysis yet, but rather I just want to run some sims to analyze the viability of my mechanisms with gravity.
My learning style seems to be that I really need to start with majorly dumbed-down training, and then once I get the basics and work with them I later excel. When I'm faced with too much at first I get overwhelmed, precisely why I was always sadly too initmidated to persue a mechanical engineering degree. 😕
But I digress. Thanks for any guidance.
@steambc wrote:
.... learn the basics so I can test a few amusement ride mechanisms that I've dreamed up.
I was always sadly too initmidated to persue a mechanical engineering degree. :/.
Purchase the Wasim Younis Book 2 (Amazon.com) Unfortunately there are a lot of errors in the book, but I look at them as "learning opportunities", just post questions here when you can't get one of the exercises to work.
I am a machinist.
I teach all of my courses from more of a hands-on practical application perspective rather than from a theoretical perspective.
If you can travel to NE Pennsylvania for 32 weeks, I have two courses that cover Dynamic Simulation.
When you get ready for FEA of your DS.
https://events.au.autodesk.com/connect/sessionDetail.ww?SESSION_ID=6583
This week - we are starting on Friction.
https://screencast.autodesk.com/Embed/Timeline/94e5c2ba-9551-4238-bc13-559fc2b6b299Thanks. I'll go ahead and order the book. Unfortunately I wouldn't be able to take your course. I appreciate the help!
