Inventor General Discussion
Active Member
0 Kudos
Post 1 of 7
Vertical Text with "Leader Text" with/without leader arrow
312 Views, 6 Replies
11-27-2013 11:44 AM
i have read through an old post... link      which unfortunatly wasn't fully answered and i have a similar question. I would like to add a Leader Text to lable a part- referencing the Part Number or whatever, move the text close to the edge of the part, to remove the leader/arrow and make the txt rotate 90deg to be vertical. I have messed with style settings for a new Vertical Txt style, and Vert Dim style -(pointed to the Vert Txt style and adjusted Notes and Leaders tab)
i don't understand why in the Format Text window the "rotation" box is always grayed out. can you unlock it?
i think the solution that the previous post was looking for would work for myself as well. does anyone know any style combination that could solve this?
thanks!!
bear
Valued Contributor
0 Kudos
Post 2 of 7
Re: Vertical Text with "Leader Text" with/without leader arrow
11-27-2013 01:01 PM in reply to: beardrafting
The only way I know how is creating a text.
Distinguished Contributor
6 Kudos
Post 3 of 7
06-16-2014 03:39 PM in reply to: beardrafting
Bear,
I still haven't found an answer to this puzzle.
The text orientation and style boxes are always grayed-out in my leader dialogue.
Have you found a solution to this yet?
I started looking since 2010, and going on 5 years later, no response from Adsk.
Imagine??
... Chris
IV 2010 Suite
Digital Storm PC:
EVGA & Intel components
Win 7 Pro 64 bit
Valued Mentor
111 Kudos
Post 4 of 7
06-16-2014 04:00 PM in reply to: beardrafting
I don't think it can be done yet. What I like to do is create a sketch in the view and place normal text and rotate it. This will allow you do "attach" the text to your view so that it will travel with it (hell, you can even project an edge and constrain the text to it so there's no chance of it wondering off). It takes two key strokes to do it: Highlight view, S, T and presto, you're placing text.
I'd like it if we could do it the way you describe, but I've found this to be a satisfying alternative for the time being.
-Will Mann
Inventor Professional 2015 : SP1 U1
Vault Professional 2015
AutoCAD Mechanical 2015
6 Kudos
Post 5 of 7
06-16-2014 06:21 PM in reply to: wimann
W,
Thanx for the tip.
I'll try it tomorrow.
If it retains the property of the part it's touching, "I'm golden".
I'll let you know how it goes ...
... Chris
IV 2010 Suite
Digital Storm PC:
Win 7 Pro 64 bit
Valued Mentor
111 Kudos
Post 6 of 7
06-16-2014 06:23 PM in reply to: cadman777
I hate to say it but it can't pull the properties from the model. The only other way I could think of that that would work might be with ilogic to pull the properties from the model them insert them into text as used parameters in the drawing but I'm not even certain that that would work tbh. Looks like you might be stuck between a rock and a hard place.
-Will Mann
6 Kudos
Post 7 of 7
06-16-2014 06:30 PM in reply to: wimann
W,
Thanx for saving me the time and trouble.
Looks like I'm stuck using this POS the way I've always used it.
Here's my work-around for this software DEFECT, based on D Jeffries help back in 2010:
Go to leader properties in Dimension Styles.
At bottom right of dialogue box change the text to align w/the leader line.
Change leader line properties to Dot & .001 & no arrow.
Then attach the leader arrow to an entity edge that's perpendicular to the parallel edge you want the text near.
Drag the leader arrow off the edge it's connected to so it makes an extension line (invisible).
Then align the text to the leader line and also parallel to the edge it's near.
Works good enough to get the job done.
If you want to see a screen shot, ask and I'll do it tomorrow.
Time to get ready for sleep.
... Chris
IV 2010 Suite
Digital Storm PC:
Win 7 Pro 64 bit
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
