Inventor Forum
Vertical Alignment of Points on Seperate Parallel Planes
1 REPLY 1
378 Views, 1 Reply
Basically, I have two workplanes which are parallel to each other and offset by a certain distance. As illustrated in the picture below, I'd like to constrain points from each plane to have the same vertical alignment as those from the other plane (horizontal too, I suppose, but the horizontal dimension will be the same anyways).
I'm not sure exactly how to accomplish this with a definitive constraint, so any help would be greatly appreciated.
Tags (3)
1 REPLY 1
JDMather
Project Geometry.
