Inventor General Discussion
Active Member
0 Kudos
Post 1 of 2
Vertical Alignment of Points on Seperate Parallel Planes
206 Views, 1 Replies
09-21-2012 05:17 PM
Basically, I have two workplanes which are parallel to each other and offset by a certain distance. As illustrated in the picture below, I'd like to constrain points from each plane to have the same vertical alignment as those from the other plane (horizontal too, I suppose, but the horizontal dimension will be the same anyways).
I'm not sure exactly how to accomplish this with a definitive constraint, so any help would be greatly appreciated.
Project Geometry.
2,129 Kudos
Post 2 of 2
Re: Vertical Alignment of Points on Seperate Parallel Planes
09-21-2012 05:45 PM in reply to: acelove27
Project Geometry.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
