Inventor Forum
VBA to Export the file as pdf and save a copy of dwg to the same location
1 REPLY 1
dfitting
1255 Views, 1 Reply
When I am done with a dwg, I am having to eport the file to a pdf to a certain location and then I am saving the file with Ctrl + S and then in windows I am copying and pasting the dwg file to where I saved the pdf to.
I am wondering if there is a way to create a vba where I can do them both at the same time?
1 REPLY 1
Mark_Wigan
in reply to: dfitting
have a look in the customisation part of the forums... you will also see that there are several add-ins that you could get from the autodesk apps exchange.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
