Inventor Forum
VBA Macro Ilogic Issue
1 REPLY 1
gazadder
3123 Views, 1 Reply
I am having an issue driving Ilogic rules from a VBA macro imported through Inventor VBA editor. Basically the only purpose of this macro is to run the very first Ilogic rule in an assembly that drives subsequent rules. However the problem I am having is when I fire the first rule with the macro then one of the subsequent rules (which are not related to the macro rule) behaves differently from when I fire the first rule manually. When I say behaves differently I mean it doesn’t recognise a line of code within the ilogic rule. I know the line of code could be placed into the macro but this is a simplified version of the problem and the code needs to be in Ilogic.
The line of code in the ilogic rule that seems to be not recognised when run via the macro is:-
ThisApplication.CommandManager.ControlDefinitions.?Item("AppZoomAllCmd").Execute
The VBA Macro is as follows:-
Attribute VB_Name = "iLogicAssy"
Public Sub RuniLogic()
Dim addIn As ApplicationAddIn
Dim addIns As ApplicationAddIns
Set addIns = ThisApplication.ApplicationAddIns
    For Each addIn In addIns
        If InStr(addIn.DisplayName, "iLogic") > 0 Then
                        addIn.Activate
            Dim iLogicAuto As Object
            Set iLogicAuto = addIn.Automation
            Exit For
        End If
    Next
Debug.Print addIn.DisplayName
Dim RuleName As String
RuleName = "FINAL_RULE_RUN"
  Dim oDoc As Document
  Set oDoc = ThisApplication.ActiveDocument
  If oDoc Is Nothing Then
    MsgBox "Missing Inventor Document"
    Exit Sub
  End If
  iLogicAuto.RunRule oDoc, RuleName
End Sub
1 REPLY 1
gazadder
in reply to: gazadder
Upgraded to 2014 and this is no longer an issue.
