Hi everyone, I've only just started using Vault for the first time in my current contract position. I don't know if this problem is vault or just a basic I haven't learnt properly.
Anyway in some of my idw's I try to save and it says certain components are not the latest version. So I've opened those up from both my local server and vault and tried to save and check back into vault. But then it tell's me I already have a later version saved so I cannot save ths one. Well try as I might I cannot find any other versions! I have tried hitting update but that didn't work.
Help!
You may need to spell it out for me 'cos I haven't had this problem before. I can't ask anyone here 'cos the only other guy has gone of long term sick so I'm in it!
You might have better luck with this on in the Vault forum. More information is needed though. What version and "flavor" of Vault are you using (ie Vault Basic, Professional etc). How are you opening the files in question, from Inventor or from Vault? How did you go about checking out the files, check out or get revision etc? Just need to know a bit more of the workflow involved, and maybe some screen shots of what you are seeing would help.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
