I meant to say concurrent, not concurred...
> 5) Vault is good at maintaining a concurred design environment, much more
> secure than semi-isolated.
Sorry,
Hugh Henderson (Autodesk)
"Hugh Henderson (Autodesk)" wrote in
message news:406deecf$1_1@newsprd01...
> John,
> Unfortunately Vault is not compatible with Linux. Vault uses SQL
server,
> and SQL server is not compatible with Linux.
> Vault has many advantages over semi-isolated:
> 1) Vault provides a better interface for managing your data
> 2) It allows you to report a version history of all your Inventor files,
> and has an understanding of all inter-related parts.
> 3) Vault stores and maintains metadata about your Inventor documents.
This
> metadata allows you to query and search for Inventor files and versions
> (e.g. If you want to find all Inventor assemblies that use a certain part,
> you can do this with Vault)
> 4) Vault provides a easy and defined mechanism to back up your data.
> There are many more advantages to Vault than is mentioned here, and best
of
> all, it's FREE to Inventor users! On the downside, you can't use Vault if
> you have a Linux server.
> Best regards,
> "ed_nelson" wrote in message
> news:12887326.1080943434483.JavaMail.jive@jiveforum1.autodesk.com...
> > I have not used semi-isolated since vault came out but from what I
> remember it very simplistic in its check in and out functionality. If you
> are going to do a lot of check in/out dont use semi-isolated.
> > Having used both I would choose vault. You get a lot more benefit in my
> opinion. However it is a little more complex overall and you may not want
to
> bother.
> > In any case read all the documentation about Vault before you use it.
Once
> you understand it, it really is simple to use.
> > You can put the file store for vault on your server but You cannot
install
> vault on your linux box though. you would have to install it on a system
> with win2k or higher and point it to the linux box. If it is a users box
you
> install it on it will be a performance hit on them when vault operations
> occur.
> > - ed -
