Yesterday, at what appeared to be random, all of my addins decided not to load into Inventor. I noticed this as I could not place parts from content center or Vault. I changed them back to "Startup/Loaded" under "Load Behavior" in the Add-in manager and restarted inventor. Content center and the Vault tab are now appearing on my ribbon. The problem is all the vault commands are "grayed out" (i.e. unselectable). Also, the "place from vault" command is back for assemblies but when clicked, nothing happens. The same thing happens for "place from content center." Any ideas on what setting/options have been reset?
Ben
Inventor 2010
Vault 2010
Windows XP Professional x64
Solved by luttena. Go to Solution.
Hello. Please go back into your addin manager and right-click on the white space. Select the option to 'Show Hidden Addins". You will see the "EDM Addin" populate the list.
Please load that addin and you will now see some more buttons (that are missing from your screen capture). Log in while a Vault ipj is active and all your commands should be available again.
Adam
