Inventor General Discussion
98 Kudos
Post 1 of 21
Vary Sketch Pattern
344 Views, 20 Replies
08-06-2012 09:41 AM
Hi Guys,
 I need a special pattern that varies the original sketch dim. Is this possible?
C1
C1
Inventor Professional 2015
Vault Professional 2015
Like this?
I changed the direction of the pattern to follow the angled edge.
1,701 Kudos
Post 2 of 21
Re: Vary Sketch Pattern
08-06-2012 10:08 AM in reply to: CAD-One
Hi CAD-One,
You can right click on one of your patterned sketch object and then choose Edit Pattern to modify your sketch pattern, Then click the >> button in the lower right hand corner of the dialog box. Then uncheck the Associative checkbox. This will make them individual objects that can be edited individually. But they'll likely need to be dimensioned in place afterward to keep them from moving around.
Depending on the task at hand, there might be a better way using a feature pattern instead of sketch pattern, but maybe not.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Employee
3 Kudos
Post 3 of 21
08-06-2012 08:21 PM in reply to: CAD-One
Could you add more info. about your issue or add one image to show the result you'd like to see?
Thanks!
Joyce-Jinghua Zhou
Sr. Software QA Engineer
Inventor Quality Assurance Team
98 Kudos
Post 4 of 21
08-06-2012 08:38 PM in reply to: CAD-One
Something like this
http://help.solidworks.com/2012/English/solidworks/sldworks/vary_sketch.htm
C1
889 Kudos
Post 5 of 21
08-07-2012 06:24 AM in reply to: CAD-One
I think this is what you are looking for.
Mike (not Matt) Rattray
98 Kudos
Post 6 of 21
08-08-2012 10:34 AM in reply to: mrattray
Nope, this didn't help. I tried it. Sent from my iPhone
C1
889 Kudos
Post 7 of 21
08-08-2012 10:36 AM in reply to: CAD-One
Can you post the part?
98 Kudos
Post 8 of 21
08-08-2012 11:53 AM in reply to: mrattray
Take a look at the attached part, I am talking about the Rectangular Pattern 1.
I am using still Inventor 2012.
C1
889 Kudos
Post 9 of 21
08-08-2012 12:05 PM in reply to: CAD-One
Like this?
98 Kudos
Post 10 of 21
08-08-2012 12:49 PM in reply to: mrattray
Mike,
I wasnt thinking that Direction.
This was a simple & great solution. Thanks to you.
C1
