Inventor Forum
Vary Sketch Pattern
20 REPLIES 20
Message 1 of 21
CAD-One
1634 Views, 20 Replies
Vary Sketch Pattern
Hi Guys,
 I need a special pattern that varies the original sketch dim. Is this possible?
C1
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
20 REPLIES 20
Message 2 of 21
Curtis_Waguespack
in reply to: CAD-One
Hi CAD-One,
You can right click on one of your patterned sketch object and then choose Edit Pattern to modify your sketch pattern, Then click the >> button in the lower right hand corner of the dialog box. Then uncheck the Associative checkbox. This will make them individual objects that can be edited individually. But they'll likely need to be dimensioned in place afterward to keep them from moving around.
Depending on the task at hand, there might be a better way using a feature pattern instead of sketch pattern, but maybe not.
I hope this helps.
Curtis
Message 3 of 21
JoyceZhou
Could you add more info. about your issue or add one image to show the result you'd like to see?
Thanks!
Joyce-Jinghua Zhou
Inventor QA Engineer
Message 4 of 21
CAD-One
Something like this
http://help.solidworks.com/2012/English/solidworks/sldworks/vary_sketch.htm
C1
AutoCAD 2020
Message 5 of 21
mrattray
I think this is what you are looking for.
Mike (not Matt) Rattray
Message 6 of 21
CAD-One
in reply to: mrattray
Nope, this didn't help. I tried it. Sent from my iPhone
C1
AutoCAD 2020
Message 7 of 21
mrattray
Can you post the part?
Message 8 of 21
CAD-One
Take a look at the attached part, I am talking about the Rectangular Pattern 1.
I am using still Inventor 2012.
C1
AutoCAD 2020
Message 9 of 21
mrattray
Like this?
I changed the direction of the pattern to follow the angled edge.
Message 10 of 21
CAD-One
Mike,
I wasnt thinking that Direction.
This was a simple & great solution. Thanks to you.
C1
AutoCAD 2020
Message 11 of 21
Fernando
Hi, i need crate a 1/4 plannar coil, and need create a vary sketch pattern, buy i not found solution, can yours help?
This is a planar surface coil over pcb sustrate FR4 (http://www.ijser.org/paper/Analysis-of-RF-MEMS-Square-Spiral-Inductor/Image_003.jpg) i need creat only 1/4 for simulate in COMSOL using 3 axis simetry. But the rectangular pattern do not vary the length of coil.
Message 12 of 21
Fernando
in reply to: Fernando
I need vary the number of turn coil from comsol to optimize the coil inductance. Because i need the pattern vary acodring vary the n parameter.
I post an example of circular coil two layer
Message 13 of 21
JDMather
Is there a reason you cannot use the Coil command rather than Equation curve?
Is there a reason you are creating multiple surface bodies?
Message 14 of 21
Fernando
in reply to: JDMather
The coil is planar, i need crear a surface coil for to simplify the method of finite elements in COMSOL Multiphisics. I need a tool that produces a variable pattern. Like this: http://help.solidworks.com/2012/English/solidworks/sldworks/vary_sketch.htm
Message 15 of 21
Fernando
Hola, por favor, me podrían enseñar cómo crear un patrón variable en Autodesk inventor?
Message 16 of 21
Fernando
Hello, please, could teach me how to create a variable pattern in Autodesk Inventor?
Message 17 of 21
JDMather
@fliozzi wrote:
The coil is planar, i need crear a surface coil ...
It might have been best to start a new thread on this topic.
See attached file for a clear surface planar coil (Spiral).
In the image you linked - the spiral is in straight lines rather than a continuous curve.
Is that what you really really want?  (I remember this same topic on the SolidWorks forum a few months ago - this is much easier in Inventor than SolidWorks - if that is what you really want.)
Message 18 of 21
Fernando
Great job!, This flat circular coil have simulated, but for ten turns of winding, the simulation takes several days. I need to make one quarter of a rectangular flat coil for use symmetries and achieve shorter simulation. The coil is shallow and is located on a printed circuit board PCB). I want to automate the process of this cración quarter of flat rectangular coil, varying the inner radius, number of laps, the track width and track separation. These parameters are controlled by COMSOL LiveLink for Inventor. I can do it manually, but I want to automatic to use optimization modules that automatically vary these parameters.
The rectangular pattern not complete the coils, and I need to be automatically completed by varying the parameters.
http://www.comsol.com/blogs/exploiting-symmetry-simplify-magnetic-field-modeling/
Message 19 of 21
JDMather
I am still having trouble understanding your design intent.
Is this what you are after?
Message 20 of 21
Fernando
YES!!!, I have to create exactly that quarter of coil, to simulate in a multiphysics program. But it has to be automatic, i can not manually create the coil because the multiphysics program optimizes geometric dimensions varying parameters directly in Inventor, such as the inner radius, coil width, coil separations, and coil turns. Thanks JDMather!!!
