Hi
I am using Autodesk Inventor 2014. In part modelling I have a feature and I want a rectangular pattern of it with variable spacing like at 2,4,7,10,13 and its random.
Is there any way of doing it in inventor? Can it be done with the help of ilogic where I can give input for the spacing?
-Sunil
Can you attach the *.ipt file here with the geometry created however you an get it done?
The CADWhisperer YouTube Channel
I am attaching the part file.
In it I want extrusion2 to pattern along length with distance between patterns 30,40,70,80,110,170.
I just want to get an idea how is it done by ilogic.
And also I don't want to suppress the extra patterns.
-Sunil
A pattern with a variable length is not a pattern.
I would model a part with all the extrusions and use Ilogic to turn them on and off as required. Sometimes there is no easy way
As of version 2016 Inventor does not support "variable" "patterns"..
Suppressing the ones you don't want is an option.
This is an old thread but I've found that this method for unequally spaced patterns is very helpful.
https://synergiscadblog.com/2013/10/25/creating-an-inventor-pattern-with-unequal-spacing/
Even more helpful is Inventor 2017...
Sam B
Inventor Professional 2017 R2
Vault Basic 2017
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
