Is there a way to pattern a feature so that the increments grow? I have a feature that needs to grow with each increment. I am using Inventor 2011.
A feature or a part component?
Maybe you can try with iCopy tool.
The iCopy will enable you to make multiple copies of an assembly that automatically resize to fit your design. iCopy creates and inserts multiple instances of the assembly, automatically adjusting the size and shape of each occurrence based on your functional requirements.
http://mfgcommunity.autodesk.com/blogs/blog/view/6/iCopy_Autodesk_Labs/
