hi,
i can't find DIN VALVE on library, trace part, part solutions, 3d model space. at libraryonly asme valve. but i find DIN or ISO valve (ball valve, swing check valve, pressure drop valve ...)
how can do this. so impartont please help me.
Do you have a manufacturer and part number for this "valve"?
Your question is confusing..
You say "I can't find DIN VALVE".. Then "but I find DIN or ISO valve"
Did you forget to attach a file?
We need the manufacturer and part number.
If you can't find a 3d model of a specific part from a specific manufacturer from common online 3d model sources then you should..
#1-contact the manufacturer and see if they have they can send you.
#2-That manufacturer has dwg files available.. Just recreate it in 3d.
You've been searching for a few days now.. If you would have just downloaded the dwg file in 20 minutes you could have modeled the valve in Inventor and moved on
yes i have dwg model 3 section 2d to 3d but i didn't it. i added dwg. because revolving feature... :(:s
Hello motaba1,
I need a help from you, can you please send me your all valve parts & Valve assembly detailed drawings. I am modelling Valve assembly in Inventor to demonstrate for my coustmer.
Please help me
Kiran Kori
Hi kiran,
i don't have very huge valve assembly or 3d library, i have a few 2d valve. i want to manufacturer and a few web sites. if you want i can send.
and web site;
